Livedash and water flow
Sassokee
Hi, I was wondering if the water flow readout would be shown in RPM from the flow meter or it would be converted and shown in L/min on the motherboard OLED display? I'd love to know so I can tell if it's worth it to get a Barrowch flow meter with build in OLED or just get a smaller 3 pin water flow meter and get the data shown via the W_Flow header.
Many thanks
Sassokee
Anyone?
Without a meter active it just show N/A , but really i think it give just rpm , like w_pump and amp ports. They cant know l/h value without tubing size value input.
Hangman_TR
Many thanks
I really need this feature on my ROG Ryujin 360
Livedash does not read any water in-out-flow parts.
How can I see the water temperatures? Does not system has a water temp sensor in itself?
