09-18-2020
12:58 AM
- last edited on
03-05-2024
07:40 PM
by
ROGBot
09-18-2020 12:52 PM
AnonGhost wrote:
hello everyone
i have asus rog strix z370e gaming motherboard and rgb light not working also i have rgb strip and if i connect strip to rgb header on mb also not working but if i connect strip via molex connector rgb strip works so can someone help me?
09-19-2020 01:49 AM
09-19-2020 01:34 PM
AnonGhost wrote:
i try different ways but still not work
i try install other versions of windows 10(right now win 10 ver 2004)
i'm try use other psus but not help
i don't know what is wrong
maybe it's trouble of bios?current version of bios 2401
i dont know how to flash older versions of bios
09-19-2020 05:07 PM
09-22-2020 01:09 PM
AnonGhost wrote:
i have ram with rgb and aio cooling system with rgb and both works normally
09-23-2020 12:31 AM
bscool wrote:
What software do you have installed to control the motherboards RGB?
When I had it were there was no RGB I installed Aura and it worked again.
https://www.asus.com/campaign/aura/us/download.php
09-23-2020 03:39 AM
AnonGhost wrote:
i try almost all versions of asus aura then aura creator then corsair icue but still not working and no need software to working onboard rgb lighting becose onboard rgb lighting enbaled in bios but in my case not working try check onboard light strip with battery and strip works i don't know what i must to do i have on board 2 rgb headers and 1 adressable header i try check all of them but now working
09-23-2020 04:03 AM
09-23-2020 11:15 PM
