04-14-2018 07:22 PM - last edited on 03-05-2024 02:15 AM by ROGBot
05-05-2019 07:21 AM
OldMike65 wrote:
Here are 3 pics that might show things better. My BCLK Frequency is set high, keep yours at 100.0000 to start out with.
04-21-2018 07:51 PM
04-22-2018 02:41 AM
will_s wrote:
the funny thing is I have a i5 8600K on the Asrock K6 and have that up to 5.1 with a lot less changes and it runs more stable and cooler
basically clock to 51 , LLC to 2 and voltage to 1.31
still having all these settings from OldMike and from De8auer will help a lot out.....they can see what others are doing
04-22-2018 03:27 AM
04-23-2018 01:46 AM
will_s wrote:
havn't tried to push the 8600K but this 8700k doesn't seem to be the best as temps get to high, I think maybe some different thermal compound as the other was a bit off ( it had separated in the tube to clear and grey ....artic silver )
04-23-2018 02:02 AM
OldMike65 wrote:
Next time you should try some Thermal Grizzly Kryonaut High-Performance Thermal Paste,its the Best you could use. Google it. 🙂
04-23-2018 06:30 AM
will_s wrote:
beat you to it...... 🙂
one of the stores I buy from has it but the shipping costs are extreme , actually more then the product so just thinking about what else I need before doing it
edit: which is the best
Thermal Grizzly Kryonaut Thermal Grease
Thermal Grizzly Hydronaut Thermal Grease
Thermal Grizzly Conductonaut Thermal Compound
