Help me OC my 8700k to 5ghz for a noob
KillaBandit
Here is my build below. I would like to see 5ghz. I have tried, and seen them core temps hit 100c with maximum heat test of prime95, and backed off. That was when I tried 1.35v and watching a youtube video discussed here before with settings. I am running at stock and 1.25v right now and stable to keep it cool till I figure this out. I know the Asus boards have a tendency to push too much V through the memory and cpu. So would like to get 5ghz, and have it not so hot either if thats possible. I am not delid. XMP is enabled for 3200.
Since I am a noob, and not very good with Asus boards, please tell me where to go to adjust the settings and what to adjust too.
CPU-Z validate. https://valid.x86.fr/levw0v
PCPartPicker part list: https://pcpartpicker.com/list/QYDXP3 Price breakdown by merchant: https://pcpartpicker.com/list/QYDXP3/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($346.89 @ OutletPC)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler ($147.49 @ SuperBiiz)
Motherboard: Asus - ROG MAXIMUS X CODE ATX LGA1151 Motherboard ($298.38 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory ($191.99 @ Newegg)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive ($119.99 @ Amazon)
Storage: Samsung - 860 Evo 1TB 2.5" Solid State Drive ($289.99 @ Amazon)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card
Case: NZXT - S340 Elite (White) ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.89 @ OutletPC)
Case Fan: NZXT - Aer RGB120 61.4 CFM 120mm Fan ($26.79 @ SuperBiiz)
Monitor: Dell - U3415W 34.0" 3440x1440 60Hz Monitor ($613.00 @ Amazon)
Keyboard: Corsair - K70 RGB Wired Gaming Keyboard
Mouse: Logitech - G900 CHAOS SPECTRUM Wireless Optical Mouse ($103.90 @ Amazon)
Other: NZXT AC-HPL03-10 HUE+ Extension Kit ($20.77 @ Newegg Business)
Other: EVGA 100-CW-1300-B9 Power Supply Cable Set ($78.39 @ Amazon)
Other: NZXT Internal USB Hub ($22.02 @ Amazon)
Other: NZXT HUE+ & Aer RGB140 Fans Bundle Pack RGB 2x 140mm Aer Fans Included ($77.39 @ Adorama)
27 REPLIES 27
Menthol
Level 14
KillaBandit,
Very nice build, excellent choice of hardware
Please post screenshots of Stress test with CPU-Z and HWmonitor or HWInfo, showing core speeds, temperatures and voltages, and screenshots of bios settings that have been changed, idle temps and volts, load temps and volts, with and without XMP enabled
What are your ambient temps
Screenshots posted not links please
There are overclock presets in your bios for 5Ghz, I believe 24/7 manual voltage and 24/7 adaptive voltage presets
Also there are many other threads here on 8700K overclocking, bios settings are very similar on X Formula, Code, Hero boards, maybe search threads here for examples
Trigger5521
I followed this video as a guide and got 5.0ghz stable right away. https://www.youtube.com/watch?v=CoUtA7DKXhU
Skip to 5:02 mark for initial BIOS settings
Further details on my particular BIOS settings
AVX negative offset -1 not -3
CPU 1.35v
My Ram is 16GB G-skill TridentZ 3400mhz I'm using the XMP profile
CPU core cache min max is 42
Good luck!
It looks like your voltage is scaling very high creating high temps and possibly some kind of throttling
Are you using manual, adaptive or offset for Vcore?
Try setting SVID Behavior to best case scenario
72930
Adaptive Vcore, 1.35, no offset
72931
CPU LL to 5 or 6
72932
Test again to check for vcore and temps
KillaBandit
Here is with not changing anything on Real Bench.
Here are the results from Real Bench.
Sun Apr 15 2018
09:41:45
Image Editing: 159785
Time: 33.3448
Encoding: 113848
Time: 46.7989
OpenCL: 110864
KSamples/sec: 20415
Heavy Multitasking: 130279
Time: 58.5817
System Score: 128694
CPU Temp: Max 72c - Min: 33c
Then I followed this guys instructions and my score went way down. http://www.overclock.net/forum/5-intel-cpus/1639998-i7-8700k-overclock-results-settings-2.html#post2...
And it seemed to hurt my performance in Real Bench? I noticed during the sound playback, when my cpu hit 100% load, it went from 5ghz to 3.9 ghz.
Any ideas whats going on?
Image Editing
87,811
Time:60.6755
Encoding
104,826
Time:50.8268
OpenCL
111,397
KSamples/sec: 20559
Heavy Multitasking
57,914
Time:131.781
System Score
90,487
Menthol
Level 14
Not to be disrespectful but personally I rarely watch these videos, I prefer to read articles, reviews and view screenshots of information
Someone will probably take the time to follow posted links and guess what settings you have made but without actual screenshots of your bios settings posted and some kind of monitoring software I hesitate to do so, it's difficult enough helping someone remotely, the easier you make it to help the more likely you are of getting help
KillaBandit
Tried that video, and this is all it got me below. But I was able to consistently keep 4.9-5ghz and no higher than 83-94c it seemed. Well, if you want me to try some different settings than the video, I can reset it, let me know what I should change then.
Image Editing
58,759
Time:90.6754
Encoding
134,768
Time:39.5345
OpenCL
111,397
KSamples/sec: 20512
Heavy Multitasking
119,033
Time:64.1167
System Score
105,989
Your VCore seems a bit high for a 5.0 ghz overclock....suggest you lower your VCore to 1.28v manually with LL6....run Prime95 for a while...if your your not stable adjust VCore in increments of .50 until you reach stability....you should be able to attain stability in the 1.30v range....Once stable...I would suggest lowering your VCCIO and VCCSA voltages as I believe they are too high...my suggestion is to start with 1.15 volts for each...and work your way up unable you again achieve stability......You should see a difference in your temps as well.
Asus ROG Maximus XI EXTREME
Intel i7 9900K OC'D @ 5.2 GHZ @ 1.345V (1.296V LOAD) LLC 6 PRIME 95 STABLE 8 HRS
XSPC RX360 Rad (6)Scythe Gentle Typhoon 1850 RPM Fans In Push/Pull @ 1500 RPMS
Swiftech Drive II / Swiftech MCP35X Pump
Enermax Platimax 1200 Watt Power Supply
32GB G.Skill F4-3866C18Q-32GTZR 3866 MHZ CL18 1.35V (OC 4266MHZ 17-18-18-41-2T @1.45V)
MSI GTX 1070 SEA HAWK EK X SLI WITH ASUS HB RGB
(5)Samsung 840 Pro 128 GB In Raid 0
(2) WD 1TB Black Edition
Corsair 900 D
will_s
not wanting to jump in and hijack but just did some o/c on my hero 8700K ( 49 at 1.34)
strange think was when running RealBench CPU-Z showed multiplier at 46 but when I run cinebench it shows as 49 (4900MHz)...temps just under 80
1562 cinebench score
Menthol
Level 14
will_s, sounds like you have an AVX offset of -3, RealBench Ver. 2.56 uses AVX
