04-14-2018 07:22 PM - last edited on 03-05-2024 02:15 AM by ROGBot
04-16-2018 06:45 AM
Menthol wrote:
will_s, sounds like you have an AVX offset of -3, RealBench Ver. 2.56 uses AVX
04-16-2018 07:14 AM
04-16-2018 05:04 PM
04-20-2018 04:49 PM
04-21-2018 12:50 AM
04-21-2018 11:11 AM
04-22-2018 06:34 AM
OldMike65 wrote:
Well everyone seems to have a different method to run @5.0 I see. 🙂 So here are mine. I NEVER use Adaptive Mode ....EVER!!! I have run lots of benchmarking apps on another forum and get very good results. Heavy benchmarking, I use Manual mode. Normal OC @5.0 OFFSET works the Best, and is very Stable. My chip is delidded & Binned. Watercooled also.
Below is a text file showing some of my main settings.
Ai Overclock Tuner [XMP]
XMP [XMP DDR4-3200 14-14-14-34-1.35V]
BCLK Frequency [100.9000] <----------> Put this @100.000
ASUS MultiCore Enhancement [Auto]
SVID Behavior [Auto]
AVX Instruction Core Ratio Negative Offset [0] <-------runs fine at 0
CPU Core Ratio [Sync All Cores] <------------
1-Core Ratio Limit [50]
2-Core Ratio Limit [50]
3-Core Ratio Limit [50]
4-Core Ratio Limit [50]
5-Core Ratio Limit [50]
6-Core Ratio Limit [50]
BCLK Frequency : DRAM Frequency Ratio [Auto]
DRAM Odd Ratio Mode [Enabled]
DRAM Frequency [DDR4-3228MHz]
Xtreme Tweaking [Disabled]
TPU [TPU II] <---- Mine is water cooled.
CPU SVID Support [Disabled] <-------------------------- Turn this OFF
CPU Core/Cache Current Limit Max. [255.50]
Ring Down Bin [Auto]
Min. CPU Cache Ratio [43] <-----Try these settings IF your @ 5.0
Max CPU Cache Ratio [47] < ---- See Above...
BCLK Aware Adaptive Voltage [Auto]
CPU Core/Cache Voltage [Offset Mode] <------------------------- Do NOT USE Adaptive Mode!!!!!
- Offset Mode Sign [+]
- CPU Core Voltage Offset [0.210] <------------------------ Try this to start with, your chip might require higher
DRAM Voltage [1.3500]
CPU VCCIO Voltage [Auto]
CPU System Agent Voltage [Auto]
PLL Termination Voltage [Auto]
PCH Core Voltage [Auto]
CPU Standby Voltage [Auto]
04-22-2018 09:59 AM
1ntel wrote:
Why do you have everything input manually but use TPU II? I thought TPU auto overvolts/overclocks etc.
Also how is your VCCIO and System Agent Voltage? I noticed this board overvolts, I set mine back down to 1.0v and 1.1v for 3200 ram.
02-01-2023 09:01 PM
