Flow and temp sensor for the Maximus xi extreme
S3RIOU5
wich sensors should i buy for my maximus xi extreme? I will try to use the 9 pin header for the monoblock that i bought. i want to build 2 loops. *
5 REPLIES 5
Spartanjet
S3RIOU5 wrote:
I don't have the answer to your question, but I was wondering who made the monoblock for the M11E I have been looking for one.
Bitspower has one I guess?
https://shop.bitspower.com/index.php?route=product/product&product_id=7126
I am still wondering myself? The Bitspower one is only one I could find.
Doza18
Do you have to remove the I/O shield and cover to install this monoblock?
The pictures show it has been removed. The cover does cover the VRM so I don't see why you could you couldn't cut the cover down to fit with the Monoblock.
