[FIRMWARE] Intel ME (H310/B360/H370/Z390)
MoKiChU
Level 40
Hi everyone,
- Intel ME Consumer Firmware :
Firmware : 12.0.94.2380 [18/05/2023]
PMC Firmware : 300.2.11.1025 [06/02/2020]
Download : Link
Check/Update Process :
Check current version : Right click on "Check.cmd" > Run as administrator
Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Motherboards with Intel H310/B360/H370/Z390 chipset.
69 REPLIES 69
MoKiChU wrote:
Hi everyone,
Firmware : 12.0.92.2145 [29/05/2022]
Firmware PMC : 300.2.11.1025 [06/02/2020]
Download : Link
Thread updated.
Thanks in advance, i'll have my Z390-F soon. If i go with Bios 2004, i need to update Intel ME ?
By the way, what are the differences between ME_Intel and MEUpdateTool and Intel ME Security
Because when i download the 12.0.81.1753v4 from support Asus, there are more files and folders in the .zip
Thanks
When you receive your ASUS ROG Strix Z390-F Gaming motherboard, and once you have updated your BIOS to the latest, use this tool to check if your system is vulnerable or not : [SOFTWARE] Intel ME Security Check (1xx/2xx/3xx/4xx/5xx/6xx)
If your system is vulnerable, you need to update your Intel ME firmware and your Intel MEI drivers (Intel ME firmware & Intel MEI drivers work in tandem).
You need these firmware/drivers for your ASUS ROG Strix Z390-F Gaming motherboard :
[DRIVERS] Intel Chipset/MEI/SATA/VMD (1xx/2xx/3xx/4xx/5xx/6xx/7xx)
- Intel Chipset Drivers
- Intel MEI Drivers (Drivers Only)
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
Drivers - 2xx/3xx
[DRIVERS] Intel Ethernet/WiFi/Bluetooth
- Intel Ethernet Drivers (Drivers Only) :
Drivers - I217/I218/I219
[DRIVERS] Realtek Audio (Intel 2xx/3xx/4xx/5xx/6xx/7xx & AMD 3xx/4xx/5xx/6xx)
You have an ASUS ROG SS3 motherboard, so :
You need Realtek Audio Drivers (UAD - ASUS ROG SS3) from the first post of the thread.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
Thanks
ME_Intel_vxx.x.xx.xxxx : This is the syntax I use for the naming of my Intel ME firmware packages (which are directly based on Intel tool, without intermediary/overlay).
MEUpdateTool_xx.x.xx.xxxx_x : This is the syntax ASUS use for the naming of Intel ME firmware packages from your motherboard support page (which are also based on Intel tool but with the ASUS ME Update Tool intermediary/overlay, hence the extra files/folders compared to my packages).
ME_Intel_Security_Check_vx.x.x.x.exe : This is the syntax I use for the naming of the Intel tool I told you to use above to check if your system is vulnerable or not.
Wow, thank you very much 🙂
MoKiChU wrote:
Hi everyone,
Download : Link
Thread updated.
Has anyone tested this version, yet? I have upgraded my firmware and I am experiencing issues using it. Booting is way slower than before and a few devices regarding Management Engine have been disabled in device manager because they don't seem like connected, e. g. management and security application local management.
its taken me this long to notice but yes i have same booting issue but i dont have anything disabled in device manager. i have a z390-f if that helps
fixed just rollback mei drivers
DmitriyS
Level 11
Thank you @MoKiChU my Maximus XI Extreme
howxcore
thanks @MoKiChU me and my maximus xi hero thank you! :cool:
Jesseinsf
Thank you MoKiChU for providing to the Asus community and for not forgetting the older hardware. 🙂
MoKiChU
Level 40
Hi everyone,
Firmware : 12.0.93.2331 [13/02/2023]
Thread updated.
MoKiChU
Level 40
Hi everyone,
Thread updated.
