[FIRMWARE] Intel ME (H110/B150/H170/Z170/B250/H270/Z270/B365/Z370)
MoKiChU
Level 40
Hi everyone,
- Intel ME Consumer Firmware :
Firmware : 11.8.95.4551 [24/05/2023]
Download : Link
Check/Update Process :
Check current version : Right click on "Check.cmd" > Run as administrator
Install/Update : Right click on "Install.cmd" > Run as administrator > Automatic restart when install is done
OS requirements : Windows 10 64 bit or more recent.
Hardware requirements : Motherboards with Intel H110/B150/H170/Z170/B250/H270/Z270/B365/Z370 chipset.
83 REPLIES 83
MoKiChU
Level 40
Hi everyone,
Firmware : 11.8.78.3689 [14/05/2020]
Download : Link
Thread updated.
MoKiChU
Level 40
Hi everyone,
Firmware : 11.8.79.3722 [25/06/2020]
Download : Link
Thread updated.
piratino
Hello there!
I never though there was an ME firmware for Z370. What is the need in installing this? It is necessary/recommended?
Thank you so much!
piratino wrote:
Hello there!
Thank you so much!
This fixes vulnerabilities of your Intel Management Engine.
You can check your system vulnerabilities with this tool : https://downloadmirror.intel.com/28632/eng/CSME_Version_Detection_Tool_Windows.zip
Go in CSME_Version_Detection_Tool_Windows > DiscoveryTool.GUI extracted folder then launch CSME-Version-Detection-Tool.exe.
- If your system is vulnerable, it is imperative to update your Intel ME firmware
- If your system is not vulnerable, it is recommended to update your Intel ME firmware
MoKiChU wrote:
Hello there!!
Well..it says my system is Vulnerable!! So I'll update.
I have mast MEI, so I should be ok updating the ME, right?
And as always... THANKS!!!!!
Warre1
I think this is the first time i don't need this since latest Bios update already included this same version.
No, your latest BIOS 2402 (ROG-STRIX-Z370-H-GAMING-ASUS-2402) does not contain the latest version from this thread :
- From your BIOS 2402 : 11.8.77.3664 [27/02/2020]
- Latest from this thread : 11.8.79.3722 [25/06/2020]
Can I install this from EFI shell? after updates my computer will not boot. So i was gonna try this but i can not boot windows OEM USB, ive tried for 2 weeks.
I sent you what you need by PM.
piratino wrote:
Hello there!!
Right.
MoKiChU wrote:
Right.
Ah! Another thing: does this "CSME-Version-Detection-Tool.exe" work also on other chipset, like the HM370 and the Z490 for identifying vulnerabilities?
Thanks!!
