Fan Control on MaximusXII Hero WiFi?
bwana
I have an AIO for the CPU hooked into the CPU fan header. I also have an AIO from my gpu hooked into the auxiliary cpu fan header. What is the least intrusive way to control these? I am leary of ASUS software due to instability and bloat. So far I had EXCELLENT results using mokichu's packages. Unfortunately he does not have packages for these accessories like ASUS fan control or AURA. I can live without the bling (I use coretemp with an addon and openRGB to set the LED colors to reflect cpu temp). Is there a way to monitor gpu temp and adjust pwm voltage of a fan header accordingly?
Intel 3770K 4.4ghz, 1.24v. . . . . . . . . . . . . .Intel 4930k 4.7ghz 1.37v........AMD 7800x3D async 104
32 gGSkill DR3Trident 2400mhz 1.65v. . . .32 g 1866 Vengeance Pro.......64 g Hynix 6200
ASUS M5G. Noctua D14. . . . . . . . . . . . . . . H110. Noctua A14x4.............Arctic 420
prime95 stable 78degrees. . . . . . . . . . . . . IBT 75 degrees
OCZ V4 OS. . . . . . . . . . . . . . . . . . . . . . . . . EVO 1TB...............................WDSN850x 2TB
Seasonic 700w. . . . . . . . . . . . . . . . . . . . . .1200AX.................................HX1200i
All tucked into Lian Li A05. . . . . . . . . . . . . .Fractal Midiv2......................BeQuiet802
bwana
I think I found it....Q-fan control in the bios....suits me fine.
