Does offset settings in adaptive mode only affect turbo speed or normal speed ?
cyanid
Does offset settings in adaptive mode only affect turbo speed or normal and idle ?
6 REPLIES 6
Nate152
Nate152 wrote:
Hi cyanid
Offset affects both turbo and idle voltage.
Thanks for the answer.
I always thought just "offset settings" affect turbo and idle, but offset in adaptive only affect turbo.
I guess I'm wrong.
Silent_Scone
Super Moderator
As above, the voltage affects the entire VID stack. If applying a suitably large offset, one needs to be wary of inducing instability at idle
panzlock
Level 12
Never you mind what the intent of this post was. It was a mistake that will remain a secret to me, and a mystery to you.
I'd like to deploy my troops in her country.
played around whit it after reading an atricle here about it.
No setting did really take.
...Since i have not found an aticle putting vcore vs LLC vs offset in a comprehensable text, i cannot say much than i have not found anybody using it on a Z370 board.
Rgds
Carlyle
Rgds
Carlyle
You might want to share info of what you played around with and how you set things up. Someone may be able to help you 😉
