05-05-2021
03:55 PM
- last edited on
03-05-2024
07:03 PM
by
ROGBot
05-05-2021 08:48 PM
05-06-2021 02:08 AM
BigJohnny wrote:
Could be the DIMM.2 itself and hopefully thats is. The other end is loss of signal from that slot through the MOBO. If it was working and you didn't change any settings in BIOS thats the most logical other than double checking the BIOS anyhow. While its not likely it is possible that its corrupted. Ive had it happen before especaially if you use the crap software AI Suite. I had that trash both roms on a dual BIOS MOBO and fortunately they were still socketed on the M8E and I bought two roms off of fleabay and installed them and flashed with the two BIOS files I wanted and did a clean install to get rid of every trace of the crappy software. Something about writes to BIOS while OS is loaded just isn't right. Not a mistake Ill make ever again. ASUS makes good hardware but the software, to be as politically correct as I am capable of, SUCKS!! AI SUITE, Crate, AURA all of it.
Just read the new posts from today, the vast majority are ASUS softrware issues and one vent on who writes this crap.
https://rog.asus.com/forum/showthread.php?124003-ASUS-who-are-you-hiring-to-design-and-build-applica...
