8086K / Maximus Hero X - Need help to switch to adaptive vcore
Asryan
Hello,
I would like to switch my vcore to adaptive but i'm unsure about the way to do it. I remember that before it was just about setting the desired one on "additional power turbo" something like this but seems it's not the same anymore
Here are my settings :
i7 8086kdelid - 4.8Ghz @ 1.2vcore
IO 1.05 IO / SA 1.1v
LLC 5
What should I do to have it stable on adaptive?
Here's what I have in the bios : https://drive.google.com/file/d/13ON7OzIOyVnBn7kMorDpceHdoqfuPmpG/view
Thanks
drop4205
Level 12
enable cpu svid support in bios and it will allow adaptive to show up on the pull down menu after that
Strix X870e-e / AMD 9800x3d / Gskill 32gb 6000 / Crucial T705 / ASUS Prime 9070 XT / Lian Li 011 compact / Lian Li Hydroshift AIO / Lian Li Platinum 1300 psu / Windows 11 24h2
Ohhh yeah i forgot about that !
And i just put 1.2 in additional power voltage?
Should i go up to LLC6 to prevent overshoot?
also i saw on this post that the adaptive on this motherboard had issue, is it still the case? https://rog.asus.com/forum/showthread.php?101494-When-are-you-guys-going-to-fix-Adaptive-Mode-OC-for...
