06-24-2018 06:21 PM - last edited on 03-06-2024 08:00 PM by ROGBot
06-26-2018 02:33 AM
Shimazu wrote:
Thinking about getting the strix z370-e but it only has two chassis fan connectors which isn't enough. I see in the spec list there's a 5-pin EXT_FAN(Extension Fan) connector that's apparently for an Asus extension card that you cant even buy and doesn't come with the motherboard. Is there anything else I can do with this connector or is it absolutely pointless which would be kind of odd?
06-26-2018 03:14 AM
DirtyMacho wrote:
The board has enough fan headers
2 in the rear out of which one is pump header.
2 in top cpu/ optional
1 in the right and
2 in the bottom
5 pin fan header support 3 fans
06-26-2018 12:18 PM
Shimazu wrote:
Should I just use two Y splitters?
06-26-2018 03:40 PM
Raja@ASUS wrote:
You can use splitters. The following conditions should be observed:
1) For chassis fan headers, the total power consumption should not exceed 12W per header (12V @ 1 Amp). Ideally, you want to give a bit of leeway for power on current surge.
2) The splitter only connects the tach signal of one fan to the motherboard header. If more than one tach signal is sent to the MB header, it will cause erroneous RPM readings.
3) The fans on each splitter should be the same make/model.
HTH
Raja
10-12-2018 11:52 PM
