Z270F can't be shut down completely when holding down POWER button
harry1511
I recently upgrade my PC with Z270F and KBL 7700K. I notice that when I need to shut down my computer with the physical POWER button on my chassis (in case I get BSOD or frozen), holding it down will turn off the system, but then in a split second the system start up again. If I release the button, the system is restarted. However, if I keep holding the button even longer, it will shut down eventually, but it is annoying because even holding the button longer, the fans and light inside the case already turn on briefly before they actually shut down.
I checked the connection, I have connected the cable correctly according to the manual. In the BIOS, I tried to hunt down the power management option so I can change it, but it seems only affect in case the power failure. I am still on stock BIOS (0505 I believe), should I update my BIOS? I heard the newest version give some high voltage when using XMP profile. Everything else is on stock atm.
Any idea?
Thanks.
17 REPLIES 17
FuryA
hi harry1511 welcome
Advice,I would like to update the 0906 and try loading to default
and check the memory modules , i,e disable XMP, set frequency manually
Hi, thanks for the advice, I am planning to upgrade to 0906, but seeing some people in this forum claim that its a little buggy, so I am still holding off. Also, everything is running with stock setting now, no XMP at the moment.
Chino
Level 15
You mentioned upgrading. Are you using the previous OS?
Also please list your complete system specifications for me. 🙂
I finished my build, and already put a fresh copy of Windows 10 on my machine.
Here is the system specs:
Asus Z270F
Intel i7 7700K
G. Skill 32 GB Ripjaws V Series DDR4 3200Mhz
Corsair Hydro H100i v2
Samsung 960 EVO 500 GB SSD, WD Caviar Black 2TB
EVGA GTX 980Ti
Cooler Master 1200W Power Supply
Everything is running on stock setting now.
Yes it is. Like I said, I haven't tweaked anything yet.
Bump.
Chino wrote:
Do you have AI Suite III or the Intel RST software installed?
I only have Intel RST installed, no AI Suite.
