Z270F: Aura doesn't work
Terepin
Lights on board won't turn on and software always crashes on startup. Here is crash dump:
https://drdump.com/UploadedReport.aspx?DumpID=13735456
Is there a trick to it?
13 REPLIES 13
Nate152
Hi Terepin
It looks like you're trying to install the X99 version, uninstall that and install Aura from the motherboard disc or go to the Asus Support Center and get the latest version for your motherboard.
Nate152 wrote:
Hi Terepin
But I did. I installed version that's available on board's support page.
Terepin
Yes. No dice.
Terepin
Tried all available versions. None of them worked.
Nate152
Nate152 wrote:
Try installing it from the motherboard disc.
Nada.
Terepin
AsRogAuraService simply won't run. It runs for 2 seconds and then it stops. I bought this board because of Aurora and I can't even use it. What the hell?!
