01-31-2017
05:42 PM
- last edited on
03-05-2024
10:29 PM
by
ROGBot
02-01-2017 12:41 AM
02-03-2017 06:12 AM
Silentspy wrote:
Did you try the latest realtek drivers?
http://www.realtek.com.tw/downloads/
I was having same issues with my Astro A40 plugged into the back 3.5mm jack. then i adjusted the Impedance to performance and it seemed to cause less distortions (Using latest ASUS drivers)
02-17-2017 12:45 PM
03-02-2017 08:23 AM
03-11-2017 02:10 PM
03-12-2017 12:00 PM
robtherobot wrote:
I'm experiencing the same issue on my ASUS Strix 270G with both the latest drivers from the ASUS site as well as with the latest drivers from the Realtek site.
It sounds like the drivers might be changing the impedance often in error. There is rapid changes in volume and distortion. If I uninstall the drivers, Windows 10 uses default audio drivers and the issue does not occur but the sound output is not optimal.
Happens with all of the headphones I tested:
Sennheiser Game One
Fostex TH-900
Beyerdynamic T5P
all of the above work fine on my ASUS RIVBE.
Has anyone discovered a workaround or has anyone seen this acknowledged by ASUS?
03-12-2017 11:26 PM
03-13-2017 12:29 PM
03-15-2017 02:12 AM
