RGB Lighting on Z270F stays on after shutdown
lazers
I have a Z270F and it's RGB stays on after windows is shutdown. I Googled and two solutions were there, one where you have option in Bios and second through Armoury Crate. I went into Bios and it only has option of Enabled / Disabled so cant do anything from there. Then I installed Armoury Crate but there is no option to control shutdown behavior as shown in some youtube videos. Maybe this motherboard is old that's why ? But still there should be an option to turn then off with computer shutdown.
Need help.
#Z270F
1 ACCEPTED SOLUTION
Accepted Solutions
Nate152
Hello Lazers
One way to get the RGB to turn off when your pc is shut down is to enter the bios, Advanded tab, APM Configuration, set ErP Ready to Enable (S4+S5).
Nate152
Hello Lazers
It worked with a minor update. I changed the ErP Ready but it also changed my On Board Configuration -> RGB to Off. So I changed this setting back to on and thus on ErP Ready was changed as suggested. This works and now my RGB on motherboard turns off when system is shutdown.
