Red Light in Dimm 2
felixreca83
Hi. My Maximus IX Apex Z270 has red light in dimm 2.
I dont like this red color, because red color can men a failure.
I have disabled Aura in motherboard, but red color continues.
What can i do?
66799
66800
6 REPLIES 6
felixreca83
My pc works correctly, but i dont like red color in Dimm 2.
Actually there is Samsung 960 m.2 256gb. I also used a Samsung 960 Pro and red color continues.
I tried both sides of Dimm 2, and red color continues.
What can i do?
Korth
Level 14
Cover the LED with a bit of tape/plastic. I used a small LEGO piece for this in my rig, lol.
[/Korth]
lufiron
Have you tried this?
66807
Thank you Lufiron. I try your option, but light continues.
Korth good idea.
I hate that light on the dimm.2. On the R6E there are 2 jumpers for LED on the dimm.2 card that clearly say L_LIGHT and R_LIGHT. Unfortunately switching the jumpers don't do anything and the LED light remains.
ohms139
Those LEDs are terrible, so bad that I've contemplated desoldering the LEDs but I don't want to damage the DIMM.2 card or possibly short out and take my NVME's with it.
I desoldered the red LEDs on my SB Recon3D; it was one the best things I ever did.
