RAM Help & Info
nufc179
Hi All I Have A MAX IV FORMULA I Have A Set of 4x 8gig Of CMK16GX4M2B3200C16 SO A SET OF 2 CMK16GX4M2B3200C16. Same Ram Same Set Same Numbers Same Timings 16-18-2T Running with XMP In Bios With 1.36v. In CPU-Z It Shows In The SPD Ranks That Slot*1 & Slot*3 Are In Dual But *2-*4 Are In Single Mode Is This Right If Not How Do I Go About Changing This 🙂
raju2529
if you have only two RAM modules in hand , and if you have four DRAM slots in motherboard , then put teo RAM modules
in 1st and 3rd
or 2nd and 4th
for more information , go through user mnaul of motherboard ., use only recommended RAM modules in motherboard model site
Intel i5 7200U_ Nvidia 940MX _Windows_11_Enterprise_64bit_22H2_buildno_22621.754
RedSector73
Level 12
This is a loot box type RAM (all Corsair LPX) the version numbers need to also match or otherwise not going to be fun, and I'm not surprised YMMV with these.
