Hey guys, I updated the bios 2 days ago to 0906 and since this has happened I can't change my XMP profile anymore. I was originally just playing around with the TPU overclocking and the screen would go black and the board was giving me ram codes so I did more investigating, I'm running G.Skill Trident Z RGB F4-3200C16Q-32GTZR 32GB. I thought it may have been one of the sticks playing up but I can increase them all to 3200 individually, but when I try and increase all 4 the computer won't start and I have to reset the CMOS. I have rolled the bios back to 0801 and I still have the same issue. Although I hadn't done a bios update previously so I may have to go back to the original bios. Is there anything else that could also be causing this I had no issues with this prior
I'm also not sure if this is related but I have been trying to adjust the fan curve in Fan Xpert 4 with it based off the water temp sensors I just added to my loop and it seems to be ignoring the curve. (The yellow dot will sit at say 20% when the curve has it plotted at 80%) as you can see in the picture below.
