New build maximus ix extreme need help
Gooch
Hi guys, and gals thanks for viewing and or trying to help. I purchased a maximus ix extreme, as i want to use all liquid cooling.
Parts
Case-DEEPCOOL GENOME ROG Certified Edition with Built-in 360 Liquid Cooling System ATX Gaming Mid Tower Computer Case- i do not reccomend buying this case for the extreme as the power does not line up, and the liuquid cooling system that came withit does not use standard fittings and ended up in the trash, had to buy all new ek parts
processor- Intel Core i7-7700K Kaby Lake Quad-Core 4.2 GHz LGA 1151 91W BX80677I77700K Desktop Processor
ram-Corsair Vengeance LPX 32GB (4x8GB) DDR4 4000MHz for Intel 200 - Red PC Memory CMK32GX4M4B4000C19R
Processor- keep getting code 55 this is listed in the qvl--------edit i first bought and tried using CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 4000 Desktop Memory Model CMK32GX4M2F4000C19 same error not in qvl
Harddrive- WD Blue M.2 1TB Internal SSD Solid State Drive - SATA 6Gb/s - WDS100T1B0B
video-EVGA GeForce GTX 1080 Ti SC Hydro Copper GAMING, 11GB GDDR5X, Hydro Copper Waterblock
Power supply-
EVGA SuperNOVA 1000 P2 80+ PLATINUM, 1000W
I built it filled it, no leaks , but on powerup i get no monitor output using hdmi port, and it stops on code 55 which says no memory present. I have 4 sticks of 8gig i have tried using only 2 and using all 4, same errors
13 REPLIES 13
Exalanoto
Did you update youre bios? Iff not, then do so.
Set XMP profile, press yes iff youre going to overclock the cpu (wich you should)
Set youre ram speed manually to 3000mhz and see it it boots
Achieving 4000mhz on 2 sticks is hard enough, wich in my eyes 4000mhz on 4 sticks seems impossibru.
I have yet to see a screen turn on. I am using onboard hdmi port is that going to work or do i need to use display port? The error i see is on the led number display on the mobo
JustinThyme
I know you are not going to want to hear this.
Pull your CPU and check that the edges of the wafer did not bend up on the corners. The Kabylake wafer material is extremely thin and 1/1000 of an inch pound too much on the cooler mounting will bend the corners up and cause exactly what you have posted. Been there and done that with a M9F/7700K.
Once removed lay it pin side down on a flat surface and look at the corners. If its just slight bending it can be cured with a little weight, if its severe it may take heat and weight. If its overly severe.............:( say goodbye and give it a proper burial. I bent mine back flat by using a socket that fit over the die and barely rested on the 4 corners. Leave on flat surfcae and put a little weight on the socket, i used 5 lbs, then leave it sit overnight so gravity can take care of it.
When installing the cooler screws just snug then like 1/8 turn past that. Crappy design not only on the thin material but the sockets where the wafer is not fully supported and the center can be pushed down causing it to bend up in the corners.
Yep that is not what i wanted to hear lol, son of a. ok so have to drain the system, remove motherboard and start anew. Is there a better processor, or steps to take to ensure i dont deal with this again. I was more worried about the pressure used to lock in the cpu then i was anything sitting ontop.
Damn, i didnt know the 7700k's were that flimsy, I just built a system for my friend, with the exact same case and cooler and cpu. I have allways in the past tightned the screws down pretty tight, and ive stoped doing that on my latest builds because i hear these kind of horror stories 😛
here are pics of the cpu mounted
Menthol
Level 14
Way to much TIM, a small pea or rice grain size in the middle is what is needed. This seems to indicate the block was not over tightened and probably did not bend the CPU
Clean then CPU and Block, remove the CPU and check for bent or misaligned socket pins or anything in or around the pins that could interfere with contact.
Remount the block following the instructions in the manual, there seems to be quite a few little washers, etc. that need installed and carefully tighten the screw evenly a little more than snug.
Test outside the case if at all possible, you don't want to go through this again
well when i was putting this PC together I did not notice that they switched the pins from the cpu to the mobo, Last pc i built was 6 years ago, been using an alienware laptop since, and it appears as though some pins have been bent on the mobo. I am ordering a new mobo as i do not think i will be able to fix the pins but i am going to try
