Need help with fans installation on Z270E
wattatrick
Hi guys!
I'm currently building my first rig that is using Z270E motherboard along with Corsair H60 liquid CPU cooler.
So I'm confused about the port in the main board. As far as I read about the fan and pump port over the internet, I decided to install the fan+radiator in the back then conect the pump of the H60 (3-pin) to AIO_pump then the Radiator's fan (4pin) to CPU_FAN. Just because I have read a lot of different info from different forum...
Is that OK to plug it like that? and do I need to set the pump to max speed or just leave it standard?
By the way, I'm using the Corsair Carbide Spec-04 case that allow up to 2 fans in front , 1 rear and 2 top. There is 1 stock fan already installed in the front, my plan is plug 3 more fans : 1 front and 2 on top. Would you guys give me an advise about place to plug all these fans? Do I have to use splitter for them or something like that ? because the others fan port right now are H_AMP_FAN, CPU_OPT, and one 5-pin extension fan connector 😉 one more thing, can I use SP fan instead of AF fan ?
66308
Chino
Level 15
That's fine.
As for the pump speed, I prefer to run my pumps always at 100%. 🙂
