Maximus IX Formula stuck on A2. Please help.
briansu
Hello,
My PC had been working fine since early 2017. Recently Intel updated their Optane support so one can accelerate a secondary HDD on a Z270 platform with Kaby Lake CPU. I installed the Optane accelerator and updated the BIOS so it supports it.
I managed to set Optane up this afternoon and it worked fine. I was able to restart the PC etc. Later at night I hibernated the PC but it someone turned itself back on (maybe the mouse moved). But when it did, the motherboard was stuck on A2. I can’t enter the BIOS as pressing DEL or F2 doesn’t work.*
Everything was working fine up until then. What should I try next??
My primary OS drive is an M.2 NVMe installed in Slot 1. Optane is in Slot 2. The secondary drives are all SATA. I also have a Blu Ray writer connected to SATA Port 6.
On the monitor the display is stuck at the point it says press DEL or F2 to enter BIOS.
Thanks in advance.*
Motherboard: Maximus IX Formula (Z270)
CPU: i7-7700K
RAM: G.Skill Trident Z PC-3200 64GB
GPU: 2 x NVIDIA 1080Ti*
ASUS Z270 Maximus IX Formula / i7-7700K 4.5GHz / ASUS NVIDIA GeForce RTX 3080 TUF GAMING OC / ASUS PG27UQ / 64 GB G.Skill Trident Z 3200MHz @ CL 14 / Samsung 960 Pro 512 GB / Samsung 970 Evo 1 TB / Seagate 12 TB BarraCuda Pro Helium / LG BH16NS55 / Corsair AX1200i / Window 10 Pro 64-Bit
0 REPLIES 0
