Hi All,
I recently purchased this board and had some questions on the audio solution. There are 3 components:
- ESS® Sabre Hi-Fi ES9023P DAC
- SupremeFX
- Texas Instruments® RC4850 op-amp
It's not straightforward how they interact with eachother.
Does the DAC operate independently of SupremeFX codec?
Does the TI Amp interact with the DAC and CODEC? Or just one of them?
Do the DAC and AMP operate from front panel output only? Or do I have the option to reroute signal to rear port?
Appreciate any insight you can provide.
