01-31-2017 02:19 PM - last edited on 03-05-2024 09:59 PM by ROGBot
02-21-2017 11:57 PM
02-22-2017 12:48 AM
Itzycharles wrote:
I just receive my hero ix big question these could apply to 6th gen CPU? Or only for new one. The oc data looks the same without some data live avx*
02-24-2017 12:44 PM
Silent Scone wrote:
http://edgeup.asus.com/2015/08/05/all-things-asus-z170-skylake-platform-overviews-build-guides-overc...
https://drive.google.com/file/d/0Bz2VRRbLPrZnMXBnOXRWeVlHcHM/view
02-26-2017 10:47 AM
02-26-2017 12:26 PM
KuraiShidosha wrote:
Does memory XMP affect CPU voltage demands? At base memory speeds my 4.8Ghz 1.250vcore is perfectly fine and stable. Can bench for hours without fault. As soon as I set my memory to XMP which is 3200Mhz, I get crashes in Realbench after only a couple minutes.
I've tried raising DRAM voltage, especially because for some weird reason the board isn't providing 1.35v like the memory asks for, it's only getting 1.344v instead. Raising that to 1.36 didn't help at all.
Then I tried raising VCCIO and SA to 1.2v up from ~1.15v. Also didn't help at all. Strangely power consumption dropped tremendously when I had the above voltages applied when compared to Auto and they were lower. Still, stability was much worse.
The only thing I can think of is raising CPU voltage. But is this normal? Does memory overclock really require a stable CPU voltage to be raised? I'm trying to keep voltage down as much as possible to avoid degradation. I'm pretty sure I've already seen some, or maybe it was just that initial burn in phase, because when I first got the chip 4.8Ghz was stable for Prime95 small FFT at 1.20v. After a few days I had to keep raising it to 1.25v to get it stable. This whole time XMP has been active but now I'm not stable at even 1.250v. That's when I decided to set the memory to standard and see what happens and yep the chip is perfectly fine at 1.250v again.
What should I do and/or be experiencing here?
02-26-2017 12:59 PM
02-24-2017 11:26 AM
Raja@ASUS wrote:
http://edgeup.asus.com/2017/01/31/kaby-lake-overclocking-guide/
enjoy.
02-26-2017 05:08 PM
