IX formula turn off led when system is in standby?
Teletha
is there a way for the leds on the board to shut off when i place the system in i.e hibernation or sleep or even when i shut it off completely?
AMD Ryzen 7950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX TUF 4090 OC@3GHz [EKWB Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | 980+950 Pro 1TB M.2 | x6 850 PRO 512GB | NAS 4x 18TB Seagate Exo Raid 10+Backblaze | Lian-Li o11D XL | Main Screen: Samsung NEO G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | Copyright©1996-2023 Teletha™ All rights reserved. ® -"Lightning. It flashes bright, then fades away. It can't protect. It only destroys."
4 REPLIES 4
Chino
Level 15
There should be a ROG Effects section in the BIOS that lets you disable the LEDs. Not sure it it works for hibernation or sleep though.
isn't that setting to permanently turn them oif even when system is on?
Praz
Hello
Assuming the power supply is compatible in the BIOS set ErP to enabled.
Teletha
i found a setting for when it is going in sleep mode in the bios!
