01-15-2017 11:06 PM - last edited on 03-05-2024 10:53 PM by ROGBot
01-15-2017 11:25 PM
WiLdJeSTeR wrote:
Hello,
I bought 16GB(8GBx2) of this G Skill Trident Z 4266 Ram Model F4-4266C19D-16GTZA before I saw the QVL. I tried to load the XMP profile in the BIOS for 4266 but it wont boot up. I tried to adjust the timings to get a slightly slower speed than 4266 to try and get the maximum out of the RAM but any settings other than what it gets set to(2133) it wont boot up. Any suggestions? Will the Trident Z 4266 be supported soon? Or am I in trouble?
Thanks
01-17-2017 04:58 PM
WiLdJeSTeR wrote:
Hello,
Thanks
01-17-2017 06:06 PM
WiLdJeSTeR wrote:
Hello,
Thanks
01-18-2017 12:10 PM
01-18-2017 06:15 PM
WiLdJeSTeR wrote:
My CPU is the kaby lake i7-7700k. Will they take back the RAM after I have used it?
01-24-2017 08:26 AM
01-24-2017 12:04 PM
01-24-2017 12:44 PM
xherics wrote:
If your RAM has JEDEC 2400MHz, so basic frequency on 2400, probably your system can not POST.
I tried 2 examples of Maximus IX Code, 2 examples of CPU, with more types of RAMs with basic 2400MHz, neither worked correctly.
But RAMs with JEDEC 2133MHz worked well immediately.
Do you have an error on your MB Q-code LED with NR 55 ?
The RAM QVL list has included so many JEDEC 2400MHz RAMs, but I suppose, that the BIOS with the true support is not yet releaset.
Formula and Code are the same MBs, just the Formula has water cooling cells...
