Hello,
This year I tried to go big (before get married), and started with a new build, threw away my old AMD (first build), and now I'm with Intel (second build).
So I bought this Motherboard Strix z270E, i7 7700K and a Corsair H100i v2... Right now I have everything but GPU... so I just turn on the PC to install Windows (so PC is clean), but in the boot screen says that I have connected a Mouse, Keyboard, SSD's and a HD, everything seems fine after this but, at the bottom of the screen appears a message with "CPU Fan Error Detected" and for help I need to press F1...
When I check the Cooler I can see that both fans are working, I have connected to a AIO? Connector in the motherboard ? Tried to put in those CPU fan 4 pin connector, but same error, and searching on web browser I found that I can connect the Cooler to that 4 pin AIO? connector and the fans to CPU Fan/CPU Opt, and after that no more error, but in BIOS menu I saw that the CPU temperature is so high (90•)... I did put thermal compound... also I noticed that one of the pins from the cooler is missing I mean it should be 4pin connector and I just have 3, Could be that the problem ?*
Sorry english is not my best and will try to answer any question asap because I'm at work and dont have access to my PC ... any help would be much appreciated
Thank you
Manuel C*
