Extreme IX monoblock water flow meter not working
keimonen
It seems the water flow meter is not producing readings from either bios nor ai suite.
Anyone else experienced this or is my monoblock just broken?
29 REPLIES 29
I can confirm above issues.
My flow meter seems to spin accurately. In BIOS n/a is shown. In Suite the monoblock flow meter shows 0.5 l/h same as flow meter 2 where is nothing connected. If I put waterpump to maximum the value springs between 5 and 9 l/h in BIOS. As in some YouTube shown you will see that flow meter isn't spinning continuously, it is sometimes stopped for short time. I think the flow meter is build in too strongly so it can't spinning free as it shoud. My flow meter seems spinning continously and I think it will have a slightly brake, so it is not free spinning and signal level is to low for display accurate values. Bye the way, the RGB lightning of the monoblock is much darker then the other Aura LED's on mainboard.
Greets Bernd
Hi all,
I just finished my first build with this mobo and I'm having the same problem. Initially, the meter was spinning continuously but I only see N/A in the bios. Now it only seems to spin if I set my d5 pump speed to max setting 5.
Since this is my first build I am a little concerned that maybe I have the intake and outlet reversed. I used the right port (facing the mobo) with arrow pointing down toward the port as the intake and the left port with arrow pointing up away from the port as the outlet. Can someone with more experience please confirm that this is correct?
Thanks
Can someone please confirm that my setup ( above ) is correct? Thanks
Yes it should.
As of the signs for flow in and out and also at product videos it seems correct. The spining of flow meter goes counterclockwise. You are on the right way.
bclhh wrote:
Yes it should.
Good to know!! Thanks for the reply.
bought this Board today and i have the same problems.
Waterflow stand still until i push my Pump to max level.....
In Bios theres always no Waterflow showing only n/a.
Is there a sulution for this problem ?
Bonjour
J’ai acheté une carte mère ASUS maximus IX Extrême le 03 août 2017
Mon bock watercooling ne s'allume pas, de plus le débitmètre ne tourne pas aussi !!
Par contre le Logo "ASUS «et l'inscription "Maximus IX" s'allume
Les branchements sont correctement faits, ce n’est pas mon 1er montage en watercooling rigide.
J’ai tout essayé :
- J’ai testé les 2 prise RGB (ne marche pas)
- Mettre le 4 Pin CPU en plus (ne marche pas) au cas où ^^
- J’ai regardé avec ASUS AURA Sync j’arrive à contrôle le Logo « ASUS » et l'inscription "Maximus IX" c’est tout
- Concernant le BIOS « Mise à jour 1009 » l’option LED est bien activée
- Dans le Bios débit de 0.5l concernant le débimètre
Si quelqu'un peux m'aider je suis preneur !!
Merci d'avance pour votre aide
Cordialement
Corsuchu
Re
après vérification hier soir aucune mesure dans le Bios concernant le Dèbimètre (je me suis tromper :()
Mesure donner N/A
Cordialement
Hello,
i have the maximus ix Extreme too and have the same problem! Aura and temp sensors are working, but not the flow sensor! i have got already the second board from the reseller. But this one doesnt work too! can i get a new block without replacing the mainboard?! I have no desire to get everything out of it. if i get only the monoblock, i would be satisfied! the flow sensor begins to turn at a pump level from 50-60 %
nio-jhonn
Esta board no muestra las lecturas por incompatibilidad de el sensor y la board, específicamente de la forma como interpreta las lecturas.
Primero los sensores envían una señal de RPM o frecuencia muy baja de aproximadamente 200rpm dependiendo de la bomba del sistema de refrigeración liquida.
Segundo esa señal la interpreta la BIOS de la board y el AISuite para convertirlas a litros/minutos u otra medida de flujo.
Así las cosas, el sistema debería funcionar correctamente. El problema esta en el factor de conversión.
En esta board para que muestre lecturas de flujo se necesitara un sensor de flujo de entre unos 2000rpm y unos 5000rpm aproximadamente. Esas lecturas son similares a las de los ventiladores (1000-2000rpm) o las bombas (1000-5000rpm). Como en estos sensores no es posible esas lecturas y por el contrario oscilan entre 100-500rpm, el sistema según su factor de conversión las detecta como cero(0) o N/A.
Es claro que el error es de ASUS al no considerar lo anterior pero existen dos o tal ves tres posibles soluciones:
1. Que ASUS corrija ese factor de conversión para que la señal del sensor este dentro del rango y se muestren lecturas de flujo equivalente.
2. Agregar un dispositivo "Flow Meter Frequency Adapter" como este: http://koolance.com/index.php?route=product/product&product_id=1057
el cual amplifica la señal del sensor a la señal normal que interpreta esta board.
3. Conectar la señal RPM de la bomba (tercer cable generalmente de color amarillo) directamente a la señal de flujo de la board lo cual es mas complejo.
Yo tengo una board Asus maximus ix extreme con los dos sensores corregidos con la opcion dos y bombas de alto desempeño.
Aclaro esto porque ASUS le da muchas vueltas al problema y no da soluciones, y quien tenga el mismo problema debe saber al menos porque ocurre.
Finalmente aclaro que lo anterior no es teórico, todo ha sido probado en laboratorio y físicamente comprobado, antes de escribir esto.
Espero les sirva esta información.
