Asus Strix Z270H and USB problems
EinarN
I have a Asus Strix Z270H MB and are having some USB issues.
After the computer has been on for some time (i usually just put it in sleep mode, not turning it completly off) the USB ports stopps working correctly.
It won't detect devices etc. and I either have to change ports or restart the computer.
Any idea on how to fix this?
Ps.
All drivers etc. are updated
8 REPLIES 8
Nate152
Nate152 wrote:
Hi EinarN
Does this happen with your system at default settings ?
Yes. Havn't changed any settings regarding USB. Have only tried disabling the USB power setting under Windows 10 which didn't help.
Nate152
Nate152 wrote:
If you have XMP enabled, reset to defaults (f5) and test sleep mode.
Will do. I had XMP enabled. How does XMP effect the USB ports?.
Nate152
It could be with XMP enabled, your ram is not fully stable and can cause issues you're experiencing.
EinarN
Legacy USB support is set to Auto and XHCI is disabled, is this correct?.
Nate152
Try enabling xHCI or If you have the option "Smart Auto" set it to that and see if this makes a difference with the USB ports.
Chino
Level 15
