AIO pump header on motherboard ?
agony22
I am seeing that Z270 ITX motherboard has only 1 Chassis fan header that I use a spliter for my 2 front Fans and work great with Q Fan control on bios and everything.
The problem is the Pump AIO header . I place there my 2 fans exhaust fans with spliter and I see them on BIOS rpms and all , But pressing Q-fan control doesn't show anything ....
Is that normal ? there is no way to control FANS on AIO Pump header ?
5 REPLIES 5
Chino
Level 15
agony22
I just plug in only the 3pin fan on the pump header ... I can see rpms on bios ... but on Qfan control I can see only CPU and Chassis Header , nothing else 😞 is it bios problem or it works like that on ITX Z270 ? I don't have 4pin PWM fan to check 😞
agony22
OMG many many many THANKS Chino ... you saved me ... I was going crazy with that.... You just solved that for me...
THANKS THANKS THANKS
