01-19-2016 10:22 PM - last edited on 03-06-2024 01:27 AM by ROGBot
01-26-2016 05:24 PM
Oxmo81 wrote:
This is my post of the problem if enyone want a little more info https://rog.asus.com/forum/showthread.php?82267-Hero-Alpha-crackling-sound-in-games
And you will find LatencyMon raport there 🙂 Hope You have a solution, I have tryed to disable one device at the time in Device Manager. It did not see eny change by doing so.
01-27-2016 08:45 AM
Celador wrote:
This doesn't look like a device issue. This clearly appears to be an nvidia drivers issue. I would recommend using this:
http://www.wagnardmobile.com/forums/viewtopic.php?f=5&t=164&sid=62860a8e168e23b517f0ff37b9e69de1
To do a complete nvidia driver/software uninstallation then reinstalling latest drivers for your pc. You should uninstall everything nvidia related in normal boot, then boot up in safe mode (for windows 10 press and hold shift then click on a reboot button in start menu, after reboot select troubleshoot, advanced setting, startup settings, restart, after reboot press F4 when presented with an option to boot in safe mode) and use this program to uninstall nvidia drivers.
You should also post a screenshot of the drivers page in latencymon like i asked so i can look at the drivers you are running on your pc. It would also help if you made a screenshot of your autostart page (on windows 10 its ctrl+alt+del and switch to autorun page) and task scheduler (run taskschd.msc). In task scheduler you should make screenshots of both main library window (click on it) and Asus sub window.
If you are running AISuite 3 - you might want to uninstall it first and use this tool:
http://rog.asus.com/forum/showthread.php?34503-AI-Suite-III-Cleaner
And see if this solves this issue before uninstalling nvidia drivers.
Lastly you should try reinstalling directx (for example if you got any game on steam that has a directx redistributable in the game folder you could use it).
01-27-2016 12:10 PM
01-27-2016 12:49 PM
Oxmo81 wrote:
I did uninstall nVidia first in normal boot, the I used the program in the link you provided. And i did update the Diret X 12, but I'm sorry to report, this did not help.
01-28-2016 04:47 AM
Celador wrote:
Actually it seems that you have 5 drivers which are causing latency issues. Are you sure you don't have something like AISuite 3 or ROG RAMCache installed? Also - have you ever installed AISuite 3 on this pc? If so - use asus removal tool on previous page just in case.
01-24-2016 01:18 AM
Celador wrote:
I am about 80% sure that all people have them but there might be various reasons why not everyone notices them.
1) Some people can't tell the difference because they used same motherboards for years.
2) Some people use software which keeps their audio channel open all the time. Fairly certain that AISuite 3 does that as well.
3) Sound issues are best heard while using headphones and not everyone does that.
4) A lot of issues seem to be related exclusively to windows 10.
5) Absolute majority of owners do not use forums and prefer to return the motherboard, use technical support or ignore issues all together.
6) ROG products are 1.5-2 times more expensive than everything else which means that there aren't many people buying them to begin with.
Combine those issues and some which i did not list - you'll get the picture.
Oxmo81 wrote:
Asus support clames it is my powersuply because it is not Intel Haswell C6/C7 compliant.
I have this PSU http://www.fractal-design.com/home/p...ewton-r3-1000w
Can this be true?
What I told about higher temperature of the CPU due to worse cooler, did made the problem worse. It was was only a system hiccup of some sort.
So it is bak to it's normal problematic self.
01-25-2016 04:29 AM
01-25-2016 08:20 AM
01-28-2016 09:03 AM
