SupremeFX & Sonic Suite 2 Update help
Itachi91422
I noticed that a driver was posted on the support page for Maximus VIII Hero board and I installed it. However the biggest issue I have so far is after I installed the software and try to install the Sonic Suite application I get these message
The Feature you are trying to use is on network resource that is unavailable
It's is looking for SS2CheckDevicesConfigutartor.MSI
I have tried to uninstall the newest driver and reinstall couple times. I don't think I would need to start fresh to get it to work either though.
Nate152
Hi Itachi91422
Go into your programs and uninstall the Realtek High Defenition Audio driver, uninstall Asus sonic suite plugins and uninstall SVLoadSense.
Once you get those three uninstalled try installing the latest Realtek High definition Audio Driver again, Sonic studio should install with it. If sonic studio does not install, uninstall those three again and install the realtek driver from the motherboard disc.
