Sound skipping when playing games
thegameksk
My set up is:
Hero Viii
980TI
I7-6700K 4,00Ghz
16 gig ram
When I play games my sound skips and cuts in and out. Im not sure what the issue is or how to fix it.
4 REPLIES 4
thegameksk
Yes I am. After some investigation: My GPU seems to lose power as a game. Just now I played for 2 hrs and my FPS starting to drop between 20-30 FPS. I turned on after burner and it had the GPU power at 10%. I ran furmark at the same time but that said the GPU was running at full power. Not sure what to think or what the issue here is.
chino wrote:
what power supply are you using?
evga suprnova 850g2 80g
Edit: Im almost positive its not a gpu issue. I ran 3d mark and my score was good. Here is the link: http://www.3dmark.com/3dm/12268489
Also ran HWinfo after the 3dmark test. Here are the results: http://imgur.com/a/W1acd
Edit: Mods please close. I found a solution.
