Sound out of sync on MAXIMUS VIII RANGER
Orici
I have just recently build a system and notices that the sound is slightly out of sync with videos and cut scenes in-game.
I have installed all drivers and flashed BIOS to 1402 (newest).
What can i do to fix this? Maybe a new soundcard can fix this?
I have:
Asus Maximus VIII Ranger
Asus GeForce GTX 980 Ti Strix Gaming DirectCU III OC HDMI 3xDP 6GB
Asus ROG Swift PG279Q
Intel Core i7 6700K 4,0GHz Socket 1151
Samsung 950 Pro Series MZ-V5P512BW 512GB (M.2 NVme)
Corsair Vengeance LPX Black DDR4 PC21300/2666MHz CL16 2x8GB
97 REPLIES 97
Nate152
Let's hope it's the cable that's causing the latency, that will be an easy fix if it is. 🙂
Something you can try in the meantime is changing the channel on your modem.
I dont have or need a modem, just a router is needed (if i want to connect more than one device, otherwise i can just connect an ethernet cable straight into the wall9.
Orici
I talked about the problem with a friend and he said it was extremely unlikely to the the fault of the network cable, the router, my speakers..
So the problem he though it was is: software/config issues, windows 10 drivers are not good enough or the problem is in my imagination.
Nate152
Nate152 wrote:
Did you show him the Latencymon test?
No. An other thing, since DP carry sound maybe that somehow causes this for me?
Orici
Reinstalled the sound and network drivers on my old computer and the DPC latency went from 6500 us to 203 us.
Nate152
That sounds much better, is the sound in sync now?
Something else to try is disabling HPET (High Precision Event Timer)
It looks like that but i'm having a hard time telling that. It looks close though. This is the old computer, so i will try to new one tomorrow.
Btw my old computer is:
ASUS Rampage IV Extreme X79
Nate152
Ok good luck and give us an update, I sure hope you get the latency solved.
reinstalled again and:
Chipset:
Chipset + samsung nvme driver:
Chipset + samsung nvme driver + MEI:
Chipset + samsung nvme driver + MEI + nvidia:
Chipset + samsung nvme driver + MEI + nvidia + intel ethernet drivers:
Chipset + samsung nvme driver + MEI + nvidia + intel ethernet drivers + Realtek sound driver:
And finally when all is installed and use my compter:
So nvidia is causing this somehow now? :s
