02-19-2016 10:38 AM - last edited on 03-06-2024 02:43 AM by ROGBot
03-02-2016 02:23 PM
03-03-2016 06:01 PM
03-04-2016 03:39 AM
Chino wrote:
All BIOS updates are under the Other section.
03-04-2016 12:40 PM
03-04-2016 01:33 PM
UnknownEngineer wrote:
Hello, just popping in to say I have had similar issues with the same mobo. I dont want to take over your thread, just maybe my input can be used as well.
Also an Nvidia GPU, I have the 970 Gigabyte G1.
My issues have been slightly different however. I have not had audio de-synch, I have had hangs (audio controller repeats what is in the buffer) and clipping. However this mostly happens on desktop, not in games, though I have had one occurrence of it happening in games too.
Things to note, I had my 970 for several months before I got the Z170 "upgrade". I remember having some kind of issues with my Asrock z77 Pro 3 with audio, I had to disable and re-enable the audio device to make it work. At the time I was on win7, my issue then was that audio would just stop all of a sudden. No clicks or extra noises, just sudden silence. I thought it was the old mobo dying, I still sort of do.
I have gone trough most of the BIOS updates asus has been making, all to no avail. No OC, nothing changed in the BIOS. And to add to my audio issues my entire PC will sometimes freeze, I have to hard reset my PC at that point. Usually happens with up times above one day.
Now for some more relevant data.
I disabled most programs that were causing hard pagefaults, corsair link, geforce experience, asus software suite everything... I think the list is longer than that. Anyhow those errors are gone. DPC issues however are not. nvlddmk.sys (nVidia windows kernel mode driver) is pumping it to 1269us Driver is 361.75. ISR is 214us, DirectX graphics kernel is causing the number.
I had more thing to type, but I can't remember them all at once, I have been trying to figure out this issue for a few months now.
03-06-2016 07:29 AM
