separate audio streams not working
dragonslayer667
i have the latest bios and their latest audio driver but i cant get front panel and rear panel audio to play 2 different audio streams.
when i check the option for make internal and external output devices playback to different audio streams it adds hd audio 2nd output to my devices but even when it shows its playing something to it i get no sound from it.
when i tell it to play from speakers it plays from Both front and rear panel(which is my headphones and my speaker).
is there a fix for this or am i doing something wrong? any help would be appreciated becuase a $180 MB that cant even do what my 10 year old dell does is BS.
toronto699
I sent u a PM on a driver that worked for me , but what driver are u using now? u said the latest version # ? I find W10 audio is messed up , in a few ways, and drivers may not fix some issues , as W10 is the main issue
I had the same issue and the w10 drivers did not fix it.
I instead found the very latest realtek drivers and used those. And now my front and rear audio streams are separated and work like how I want them too and how I understand you want them too.
just google for latest realtek hd audio drivers windows 10 and that should lead you in the right direction (unsure if I can post links here).
