11-14-2016
01:13 PM
- last edited on
03-06-2024
01:30 AM
by
ROGBot
11-14-2016 03:03 PM
11-16-2016 10:04 AM
Chino wrote:
If I had to guess, I'd say socket temperature.
11-14-2016 03:21 PM
11-16-2016 10:09 AM
Korth wrote:
Here's a simplified Intel FAQ page and a detailed Intel document about Intel's processor temp monitoring.
Your i7-6700K has a variety of Intel Thermal Monitoring Technologies. One DTS (Digital Thermal Sensor) adjacent to the IHS reports "TCase" (overall package temp, rated max 64C). The four on-die IA-DTSs report the temps "within" each of the four CPU cores. The on-die GT-DTS reports temps "on the CPU cores" of the Intel HD Graphics 530. Two more DTSs are located near the "middle" of the Shared LLC (L3 Smart Cache) segment and in the DMI3 Uncore (DDR4 iMC and PCIe iLC) segment to provide "Thermal Monitor 1" and "Thermal Monitor 2" deltas for an internal thermal monitoring program running in processor microcode - and these two DTSs are apparently "hardwired failsafe dead-man's switches" which cannot be overridden by any off-processor signals or software. The processor also has a variety of "sideband" signals (like THERMTRIP# which can be sent through electrical pins, firmware, or software) which interface directly with the motherboard chipset (an Intel GL82-family PCH part).
I don't know which DTS probes are present and where they are physically located on the MAXIMUS VIII. A DTS can take a variety of forms, ranging from blocky multi-pin ICs to large resistor-like packages to tiny flimsy little slips of foil.
"CPUTIN" is typically surface-mounted on the PCB immediately underneath the CPU socket, sometimes mounted on the opposite side of the PCB.
"AUXTIN" is sometimes surface-mounted on the PCB immediately underneath or in proximity of the main PSU connector.
"SYSTIN" can be anywhere, sometimes adjacent to the Southbridge (if present, lol), sometimes adjacent to the VRMs.
And the famous ROG Chip sitting near the very middle of every ROG motherboard is a mysterious ASUS-programmed ASIC/MCU, it's basically a whole little computer in itself, it might implement more (undocumented?) Asus temp monitoring/control.
11-17-2016 03:23 PM
