Hi all thanks in advance for taking the time to read this and chiming in if you feel you can help.
I built a new rig almost two weeks ago and it has been running amazingly until just two nights ago when I suddenly started getting "WHEA_uncorrectable_error" bluescreen in windows 10. From there it got progressively worse, happening pretty much right after boot up and then it got to the point where it was freezing before even loading windows.
I read that, that error is commmonly associated with overclocking, however I have yet to overclocked this rig yet. I then read that turning up the VCore voltage may even correct this problem but that did not help and lead to me getting an overclockinh failed error. After some tinkering, I now notice that when I boot up and go into UEFI BIOS, it freezes up and will not accept keystrokes or mouse movements after about 5-10 seconds.
I then went through removing hardware one at a time but nothing was making a difference. That is until I removed my Swifttech H220 Prestige waterblock. I booted it up after that and voila! it booted right into windows. However, of course my skylake was getting hot as hell so I shut it off quick. So now I am trying to determine how this waterblock is causing my cpu to fail until I realize installing a stock intel fan causes the same issue. I am now in the position of not knowing if my problem is the mobo or the cpu or both at this point.
Note, I read an article that third party coolers have been warping i7 Skylake chips due to them having thinner substrate than previous generations, it seemed like a viable answer to my problem but I do not see any "warping" damage at all as the pictures associated with this problem show. And if that is the case am I now screwed when it comes to RMAing the mobo? Any help at all would be greatly appreciated, sorry if the post is too long!
Hardware:
Maximus VIII Formula Mobo
i7-6700k 4.0ghz
GTX 980ti
2x Samsung Pro SSD
2x 8gb G.Skill TridentZ DDR4 3100MHz
Swiftech H220-X2 Prestige Liquid CPU Cooler
Thermaltake TOUGHPOWER 850W Platinum Power Supply
