Problems with DDR overclocking after changing 6600k to 7700k on Asus z-170K
Tiranys
I decided to replace 6600k with 7700k. Asus z-170k motherboard.
Before the replacement, there was RAM with XMP profile at 3200, two strips for a total of 32 GB. Everything worked and started up fine. After replacing the processor, the memory refuses to start faster than 2400, just a black screen at the BIOS loading stage. I've racked my brains, I don't know how to fix it. I really hope for tips, maybe there was already someone here who solved this problem.
I bought a used processor, but according to temperature tests everything seems to be ok. The BIOS is also updated. If the problem is in the processor memory controller, then I don't know how to check here. Now I'm wondering if the processor will return to the seller and I myself will again sit on the 5th, but with faster memory. I bought the processor for playing VR, so that there would be less stuttering due to the threads, now I'm wondering if I've lost performance, because the I5 worked at 4.4 GHz. I don't want to upgrade the computer more yet, the new hardware is controversial, and I don't want to compromise with previous generations.
0 REPLIES 0
