Problem with Optical S/PDIF
lev
Somebody used Optical S/PDIF and Sonic Studio 2? Jack 3.5 there is no problem, Sonic Studio 2 runs. if used Optical S/PDIF error: "Sonic Studio does not support the current default audio device. Please switch devices to continue using Sonic Studio”. MAXIMUS VIII RANGER, Windows 10 64-bit. Realtek Audio Driver V6.0.1.7629(SonicSuite V2.2.16) for Windows 7 32bit & 64bit / 8.1 64bit / 10 64bit
13 REPLIES 13
Nobody uses or no one has a problem?
Chino wrote:
I'll find out for you.
Has there ever been an outcome to this?
Legolas
Did you ever try the older version?
http://dlcdnet.asus.com/pub/ASUS/misc/audio/Realtek_Audio_Win7-81-10_V6017629.zip?_ga=1.3269424.1685...
let me know if it works?
Sincerely,
Legolas
Сhecked, does not work too.
SonicSuite 2 new versions separately can be anywhere download or only www.asus.com?
deybdeybdeyb
Yup. I got the same issue, both from M8H and M8F:
57207
I'm using SteelSeries Wireless H.
I have the same issue, using logitech z906 with optical cable and I'm getting the same error.
In short: this is unfortunately normal - by design of Asus.
I found an older post some time ago with the same question. An Asus employee said that their sound technicians disabled Sonic Studio for S/PDIF.
The reasoning was that people that use S/PDIF typically use a home theater system with effects on its own and that they want/need a pure signal
coming from S/PDIF.
Obviously It would be best to give the user the choice, but I doubt they will ever change it.
