Possible fix for audio/sound popping issues with z170 motherboards
Celador
In case you've been suffering from the same audio issues described here:
https://rog.asus.com/forum/showthread.php?82320-This-audio-issue-has-to-go-Please-see-for-audio-file...
https://rog.asus.com/forum/showthread.php?83652-Hero-VIII-sound-issues-(yet-another-thread)
https://rog.asus.com/forum/showthread.php?84003-ASUS-ROG-Maximus-VIII-Formula-Sound-and-shutdown-iss...
https://rog.asus.com/forum/showthread.php?77456-Realtek-drivers-open-and-close-audio-channels-and-ca...
https://rog.asus.com/forum/showthread.php?76546-Popping-sound-issue-on-VIII-HERO
Try removing the Realtek driver completely as well as Sonic Studio (in case it doesn't uninstall along with the driver), reboot the pc, go into windows updates and search for new updates. If you are lucky - you'll get a new update with a Realtek sound driver. Let is install then reboot and check if this fixes the issue.
Not 100% sure but it seems to have worked for me. It installed 7836 version dated 21/05/2016 and it doesn't include Sonic Studio but at least i don't get that obnoxious popping sound every time something starts or stops playing.
I've stopped using Realtek drivers completely 2 month's ago and started using stock windows drivers (no changes in sound quality by the way in case you are wondering) but few days ago i've installed new windows updates and it forced the sound driver on me as well. Turned out - it didn't have the same popping issues as all other drivers did.
Hopefully it works for everyone else as well.
brkkab123
Can anyone tell me if this issue occurs if you have a Maximus VIII Hero motherboard and are using Logitech 5.1 speakers hooked up to it ? I'm waiting for Newegg to send me a new motherboard back to me next Wednesday. I'll be doing my build the following week.
PC Specs:
Mobo: Maximus VII Hero
CPU: Intel i5 6600K
M.2 SSD: Samsung 850 EVO 500GB (Windows 10 Pro xx64, Programs & Games that will fit
SSD2: Intel 480GB - Games that won't fit on Samsung
HDD: Seagate Barracuda 3.0TB
CPU Cooler: Arctic Liquid Freezer 240 (push/pull)
Case: NZXT Phantom 820
RAM: G Skill Ripjaws V DDR4 3200 2 kits totaling 32GBs
PSU: EVGA SUPERNova 1000 watt
darkempire
Same here .. sometime's i hear a tick sound very enoying never know where it come from
