11-02-2016 11:18 AM - last edited on 03-06-2024 01:33 AM by ROGBot
11-02-2016 12:53 PM
11-02-2016 05:30 PM
Nate152 wrote:
Hi adiwitko
Welcome to the ROG forum.
Reset to defaults and try 1 stick of ram in all 4 dimm slots to make sure all dimm slots are working.
Let us know how this goes.
11-02-2016 06:32 PM
11-03-2016 04:24 AM
Nate152 wrote:
Thank you
Code 55 = Memory not installed
Since none of the Dimm slots are detecting any ram you can try a bios update.
This can also be caused by an over tightened cpu cooler putting uneven pressure on the cpu socket or you could have some bent cpu socket pins. You could inspect the cpu socket in good light with a magnifying glass to see the pins are all straight and in order.
Or you could have a faulty cpu or motherboard.
If a bios update doesn't help, post us a picture of the cpu socket if you can and we'll go from there.
11-03-2016 05:25 AM
11-03-2016 10:55 AM
adiwitko wrote:
So, today i recived my new PC parts for my new build those being the I5 6600k, G.skill tridentZ 16gb 3200Mhz and ofc the motherboard being the Maximus VIII Hero.
The problem im encountering right now is that im getting the Q-rcode of 55 everytime i boot, when trying to do the memOK feature on the motherboard the dram light starts blinking like it should but once in a while the red one blinks for some reason.
I really need help as i dont know whats faulty and what to do about this.
Thank you in advance
