On board sound vs a sound card Asus Hero VIII for FPS gaming
gianquittia
Has anyone compared the onboard sound to a dedicated card, such as the Asus Xonar Essence STX. I was just curious if it is worth adding a sound card for directional sound pinpointing playing FPS games or the onboard sound is good enough. I was thinking of getting the Beyerdynamic MMX300 headset or Audiotechnica AD700x headphones with a mic added on.
8 REPLIES 8
Nate152
Hello gianquittia, welcome to the ROG forum !
The Hero viii has the new ROG SupremeFX 2015 audio which is an upgrade from previous ROG boards. I haven't tried it yet but with sonic studio II it gives 7.1 audio through a stereo 2.0 headset. Sounds pretty sweet to me.
Try with the onboard sound and if you're not happy with it then go with a sound card.
Chino
Level 15
Audio is subjective. I would say you use the onboard audio for a while. If you're not satisfied, then buy a sound card. 🙂
Janne-71
For myself i can say onboard audio is good enough. I used to have soundcard in my old system (Asus xonar dgx or something) and i prefer onboard sound of maximus viii hero to it. That's why i didn't even install the card in my system. Hard to say about higher tier soundcards, they could be different story but onboard audio is good.
BOLOYOO
I've never had a dedicated sound card, but compared to previous integrin SupremeFX is heaven and the earth. For me the sound is more than satisfactory, but a separate sound card may be even better - I don't know.
Had been using xonar dx for years till it died recently now using onboard supreme fx but getting wierd saw like interference on occasion, any ideas?
wils07
G35 headset no need for soundcards
pills
I have a Hero VIII and SoundBlaster Z card and just did a light sound test, definitely sticking with my Z. Nothing too thorough simply fired up Crysis3 and played around in the first map for a bit and recorded my average FPS at certain points. With the onboard audio I was getting about 6 fps less than when I had the Z going, however, I don't think it was apples to oranges. My Z is running 5.1 via optical to my old Logi Z680's but could't for the life of me get optical 5.1 with onboard to work and had to do 5.1 via green/black/yellow audio cables, not sure if that makes any difference. Many people will give you different answers on this but IMHO for my setup I think dedicated is superior, as I'm offloading some of that work from the mobo onto my Z and in my experience dedicated card software is less buggy and a less pain in the ass to configure than Realtek's stuff.
I5-6600k @ 4.7Ghz @1.385v | Corsair H100i cooler | Asus Hero viii | 16gb Gskill Ripjaws V 3000 CL15 | EVGA 980ti SC 6GB | 500GB Samsung 960 Evo | 1TB Samsung 850 EVO
Did you tried the front panel connector for audio out?
I read here that the sabre dac and headphone buffer, needs drivers and is only in front panel:
http://www.overclock.net/t/1568154/asus-north-america-asus-z170-motherboards-q-a-thread/4500#post_25...
http://www.overclock.net/t/1568154/asus-north-america-asus-z170-motherboards-q-a-thread/4510#post_25...
