11-09-2016
03:08 PM
- last edited on
03-05-2024
01:48 AM
by
ROGBot
11-09-2016 05:12 PM
11-09-2016 06:13 PM
11-09-2016 11:48 PM
08-13-2018 05:49 PM
jpgodwin wrote:
Thanks for replies
Yes, antenna connected and drivers installed. Have tried cleaning the antennas, switching sides, removing them, I've reset the bios, reinstalled windows, reinstalled bluetooth drivers, upgraded all other drivers, formatted and reinstalled windows, formatted and reinstalled with a different version of windows
Thanks!
02-05-2017 07:44 AM
02-05-2017 08:52 AM
scgt1 wrote:
I have the same issue. Just picked up a bluetooth keyboard. Turned on both wifi and bluetooth in onboard devices then installed the wifi and bluetooth driver. I'm sitting on the manage bluetooth devices screen with bluetooth on and it just shows it's searching for devices with the dots running across the screen.
05-30-2017 06:18 AM
GotKevlar wrote:
Many BT devices wont show as discoverable unless they are in "pair" mode. This is dumb question but you have that on at the appropriate time, correct?
05-30-2017 06:37 AM
Eleiyas@ASUS wrote:
I have to agree here;
if Windows is actually looking for bluetooth devices, then it says to me that bluetooth is working, just that it cannot find anything (which may indicate the hardware you are trying to set up isn't properly configured [[set to pair mode]])
06-01-2017 06:33 AM
xfactor wrote:
No windows says no bluetooth hardware on my computer, no option to turn it on etc. I install the drivers and it's not there.
