12-13-2016
08:54 AM
- last edited on
03-06-2024
01:23 AM
by
ROGBot
12-14-2016 01:40 AM
trainut wrote:
pc working fine for weeks ,at 4.5 i7 with 32 gbs fury hyper x. ddr4 2666 mhz this morning for no reason I can see no boot. looked up q codes 1st was 32 after a reset and clear c mos 99 I then replaced with 16 gb g skill 3000 MHz which I had spare booted up fine / question is how can I test my 32 gb memory fo faults dave
12-14-2016 02:09 AM
12-14-2016 08:48 AM
12-14-2016 08:56 AM
NemesisChild wrote:
Do not split the sets, run each set in each dual channel configuration.
However, it's not advisable to run mixed sets of memory, even if it's the same brand & model.
Did you try booting/posting after returning the bios settings to stock/default?
You might want to run memtest on each set individually.
12-14-2016 10:30 AM
12-14-2016 01:28 PM
12-15-2016 02:44 AM
12-15-2016 04:38 AM
