Maximus VIII Ranger crackling noise/sound from CPU or I/O Activity
Kedas
When I plug my speakers in the back and I move the mouse or scroll I hear clearly background sound. (a bit like the old modem sounds)
I don't have it on my USB headset, so it must be added on the analog out line.
The audio cable has chokes on both ends, I assume it's already present on the signal leaving the motherboard.
(I did not have this problem with my previous PC with the same monitor speakers so I assume it's a motherboard problem)
When I mute the main volume in windows I still get the same sound, so it must be added somewhere at the end.
Anyone having the same problem?
Any solutions?
System:
Antec Midi Tower P100 ATX
Antec Edge EDG550 550W, Modular
Asus ATX Motherboard Maximus VIII Ranger
Corsair 2x16GB, DDR4, PC21300, CL16, Vengeance LPX Series
Intel Skylake Core i7 6700 3.40GHz 8MB Box
Windows 7 SP1 64bit
edit: Currently I'm using audio over displayport to my monitor speaker so I don't have the problem but that doesn't solve the analog outline if I would want to use it.
0 REPLIES 0
