03-22-2016 01:45 PM - last edited on 03-06-2024 02:34 AM by ROGBot
03-22-2016 01:58 PM
03-22-2016 04:15 PM
Code_Frenzy wrote:
As a quick test and a way to narrow down the cause of the fault, can you control the fan speed using PWM whilst in the BIOS?
03-22-2016 03:38 PM
03-22-2016 05:23 PM
03-22-2016 06:04 PM
Odaik wrote:
OK, tried as suggested. On one of the Chassis Fan headers, the CPU cooler fan behaves in exactly the same way. If I set DC mode, the header controls the fan just fine. If I set it to PWM or auto, the fan runs full speed.
Reconnecting the fan cable didn't make a difference unfortunately.
03-29-2016 08:01 AM
