02-19-2016 06:47 PM - last edited on 03-06-2024 02:46 AM by ROGBot
02-19-2016 10:24 PM
02-20-2016 01:33 AM
Chino wrote:
How are your temperatures with the TX3 EVO?
02-20-2016 06:25 AM
02-20-2016 07:05 AM
02-20-2016 09:18 AM
Nate152 wrote:
Hi daemondotexe
Give us an update and let us know what water cooler you went with and what temps are, you should be able to do some overclocking.
It's normal for your cpu to stick at 4.0GHz with turbo disabled, enable it after you get your water cooler installed and tell us what voltage your cpu is drawing at auto/stock settings.
My 6700k was drawing 1.44v with stock settings by just setting the windows power plan to high performance, not a big deal though I can hit 4.75GHz - 4.8GHz with 1.488v. Your cpu is likely getting over volted on auto settings, you can manually set a lower voltage to help bring temps down.
02-20-2016 09:41 AM
02-20-2016 10:09 AM
Nate152 wrote:
It's not necessary to install the Intel graphics driver since you have a 980, you can skip it I don't install it either.
02-20-2016 10:19 AM
02-20-2016 10:22 AM
