MAXIMUS VIII FORMULA vs GEFORCE 1080GTX SLI NOT WORKING
john_ianne
hello to everyone,
My 1080 GTX SLI it is not recognized by the motherboard.
I put my cards on: Slot PCIEX16/X8_1 and SLOT PCIEX8_2
from bios this is the situation:
58117
if individually installed, cards work on both slots
My Hardware:
- ASUS MAXIMUS VII FORMULA bios version 1701
- INTEL 6700k
- RAM 16GB CORSAIR DOMINATOR PLATINUM 3000Mhz
- SAMSUNG EVO 850 512Gb
- WD RAPTOR 3x150GB
- DVDR PLEXTOR SATA
- ASUS ROG PG278Q
- GEFORCE 1080GTX FOUNDERS EDITION SLI
Previously i had Asus GeForce STRIX-GTX980Ti-DC3-6GD5 SLI and sli was perfectly.
My motherboard has a problem or is incompatible with the new GeForce 1080s?
Thanks in advice!
5 REPLIES 5
NemesisChild
Level 12
Welcome to the forum!
Have you tried swapping out the SLI bridge?
What PSU are you running? Check the PCI-E PSU cable connections.
Are both cards detected in Device Manager?
Run GPU-Z, are the cards using the same bios version?
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
I tried with another SLI bridge but nothing has changed
I have Enermax Galaxy 850W PSU (i checked the cables and they are ok)
Device manager on win10 64bit show only one GeForce 1080GTX
Running GPU-Z and the card have both same bios version (86.04.17.00.01)
NemesisChild
Level 12
So your 980's worked in both PCI-E slots?
How old is your Enermax PSU? And which model is it?
The only two common components is the PSU and Mobo. So if your 980's worked on this board, then that leaves the PSU.
Follow me here?
I have the same problem with my z170 deluxe(latest BIOS). Second 1080 is not detected. The 2 980ti i had installed before worked fine. Both 1080 work fine in the first slot
